Dec 3, 2025 1:25 PM UTC
December 2025: Driving the next wave of design innovation with Creo+ 13.1
- 0 replies
- 598 views
- Translate All
Creo+ continues to deliver new enhancements designed to accelerate your workflows and boost productivity. With over 40 new enhancements across user productivity, composites, ECAD, simulation, manufacturing and more, Creo+ 13.1 helps you to deliver your best designs in less time than ever before!
- Smarter Electrical Design: In Creo+ you can now build harnesses as assemblies for structured data management, component reuse, and easier collaboration in multi-user collaboration sessions.
- Intelligent MBD: Pattern recognition in GD&T Advisor helps to define patterns, capture design intent, and maintain associativity for faster, more accurate annotations. As your model evolves, the pattern recognition feature will adjust accordingly.
- Advanced Surfacing: Enjoy smoother, higher-quality surfaces with improved flexibility in control point manipulation and faster performance – even on the most complex models.
- Simulation Upgrades: ANSYS solvers have been upgraded to version 2025 R2 to deliver enhanced security and improved mesh defaults for greater fidelity and confidence.
- Composites Enhancements: Greater robustness in solidification, support for draping along curves, and better handling of missing materials.
- Manufacturing Efficiency: Automated intent chain creation at beam-shell intersections, and a new side milling tool for efficient undercut machining.
- Collaboration: teams can now delete unwanted branches in collaboration mode to stay aligned and keep projects clean.
Creo gets better and better with each release, helping you to deliver the right product at the right time.
Read the release notes to learn more.
