Prismatic & MultiSurface Milling Tips & Techniques Session Recording (West Coast)
Check out this video on Prismatic & MultiSurface Milling from PTC Application Engineers
Presenters: Lee Goodwin (Technical Specialist, Principal) and Ryan Butcher (Technical Specialist, Fellow)
Original Date Presented: October 12, 2021
To dive deeper into the subject, check out PTC University.
Webcast Q&A
Question from Andy:  Can Creo create a complete machine template?
Answer:  Absolutely, you can model those in Creo, however we don't simulate the entire machine.
Webcast Q&A
Question from Chris:  Is the template available from the intel library?  Where can i find it?
Answer:  Templates can be created by you to define various approaches to mfg specific geometries.  Then they can be reused for future mfg models.
Question from Chris:  How about the fixture template?
Answer:  There is a library of fixture templates.  You can modify templates from the library or build your own also.
Webcast Q&A
Question from Michael:  Can you use this tool to create a post for a 3-axis laser for sheetmetal NC?
Answer:  Yes, it would be created as a mill.
