7-Bedrock
Sep 16, 2020 4:57 PM UTC
2 letter mapkey not work when first leter is same
i record some mapkey for measurement tool.
mapkey m @MAPKEY_LABELMeasure summary;~ Command `ProCmdNmdTool` 1;
mapkey ml @MAPKEY_LABELmeasure length;~ Command `ProCmdNaMeasureLength`;
mapkey md @MAPKEY_LABELmeasure distance;~ Command `ProCmdNaMeasureDistance`;
mapkey mc @MAPKEY_LABELmeasure cycle;~ Command `ProCmdNaMeasureDiameter`;
mapkey ma @MAPKEY_LABELmeasure area;~ Command `ProCmdNaMeasureArea`;
mapkey mv @MAPKEY_LABELmeasure volume;~ Command `ProCmdNaMeasureVolume`;
m works fine, it can acticated anytime.
But when i use ml, or md, the comand always goes to m.
Looks like two letters doesn't work.
BenLoosliAnswer
Sep 16, 2020 5:09 PM UTC
Two letter mapkeys work fine.
Your problem is that when you press the M it triggers the single letter 'm' mapkey every time.
Rename your mapkeys!
This is not a new problem, it has always been there.
BenLoosli23-Emerald IIIAnswer
Sep 16, 2020 5:12 PM UTC
The issue here is that you have a mapkey "m". One letter mapkeys are normally frowned upon because they are prone to breaking other mapkeys. In your case, any mapkey that starts with the letter m will be broken by your single character mapkey. The m mapkey will always run before you type the second character.
We try to make all of our mapkey sequences at least 3 characters for this reason.
Ty
Dale_Rosema
Sep 16, 2020 7:54 PM UTC
Today you also have to be aware of the "special" keys that Creo puts into the software like "S" for sketch. Therefor any mapkeys starting with "S" are subject to fail.
See this discussion:
https://community.ptc.com/t5/System-Administration/Mapkey-Shortcut-Key-conflicts/m-p/568901
Hope this helps.
Sep 16, 2020 8:08 PM UTC
Or just turn off all the keyboard shortcuts lol...
I really don't like the customization.ui file concept. I like to be able to edit things just like we can edit config.pro files. It's impossible to tell what is being saved into the customization file. It's also too easy to mess up.
Dale_Rosema
Sep 16, 2020 8:15 PM UTC
I am not really customizing, but trying to avoid the conflicts that Creo puts in as "Standard".
