3-Newcomer
Jun 20, 2014 5:56 AM UTC
2D Drawing file problmes
When I try to opend the frm file in my Creo.
I have following message, and I cannot opend the file with this message.
"Could not read from Model Tree config file C:\ProE\tree.cfg"
Does anybody know how to resolve this problems?
I try to make new drw file with the frame, It happens.
Bong
jsarkarAnswer
Jun 20, 2014 7:28 AM UTC
I guess your tree file options is set, check default config. pro file. delete the option or reset the file.
you may check that tree.cfg file is exists in C:ProE or not, if not you may copy one there named tree.cfg.
jsarkar1-VisitorAnswer
Jun 21, 2014 12:00 AM UTC
Here is an article that should be helpful.
https://www.ptc.com/appserver/cs/view/solution.jsp?n=CS25177&source=tssearch
You likely have config.pro option "mdl_tree_cfg_file" set to a file path but the file does not exist in that location.
