Feb 20, 2012 4:38 PM UTC
64-bit Wildfire 2.0 on Windows 7 64-bit
I posted this to the Admin group but didn't get any solutions so I figured I'd try the general group.
Has anyone successfully installed and run the 64-bit version of Wildfire 2.0 on 64-bit Windows 7? Getting the 32-bit version of Wildfire 2.0 to run on Win7x64 wasn't actually that hard with some help from some information I found on the web but the 64-bit version won't seem to run. I couldn't get the x64 setup.exe to run on Win7 so I first installed it on an XPx64 and it installed and ran fine, even integrated with Intralink 3.4 M050. Then I copied the installation to the Win7x64 machine and ran ptcsetup.bat to set the environment variables and all seemed well. Unfortunately when I tried to start Wildfire 2.0 all I get is a brief command window flash and then nothing.
Any help would be appreciated.
Regards
Mark Dolata
CenterLine (Windsor) Ltd., Automation Components Division
email:mdolata@cntrline.com
Feb 29, 2012 4:00 PM UTC
Mark,
Myself and a colleague are attempting the exact same thing, and having the exact same results. Very frustrating! In our case it doesn't have to integrate with Pro/I (of any version), but we still have some need to run the older version. If you should find a solution, please let me know; I will do likewise.
Jim Augeri
Honeywell International
Albuquerque, NM
