Jan 10, 2012 4:07 PM UTC
64-bit Wildfire 2.0 on Windows 7 64-bit
Has anyone successfully installed and run the 64-bit version of Wildfire 2.0 on 64-bit Windows 7? Getting the 32-bit version of Wildfire 2.0 to run on Win7x64 wasn't actually that hard with some help from some information I found on the web but the 64-bit version won't seem to run. I couldn't get the x64 setup.exe to run on Win7 so I first installed it on an XPx64 and it installed and ran fine, even integrated with Intralink 3.4 M050. Then I copied the installation to the Win7x64 machine and ran ptcsetup.bat to set the environment variables and all seemed well. Unfortunately when I tried to start Wildfire 2.0 all I get is a brief command window flash and then nothing.
Any help would be appreciated.
Regards
Mark Dolata
CenterLine (Windsor) Ltd., Automation Components Division
email:mdolata@cntrline.com
