Jun 18, 2010 2:34 PM UTC
64bit Pro/INTRALINK Toolkit?
All,
I think I know the answer to this but I wanted to make sure. Has anyone
compiled a Pro/INTRALINK Toolkit application that is 64 bit? I thought
the toolkit only shipped with 32 bit libraries to link with but I wanted
to know if anyone used some "black magic" to get it to work. Thanks.
Patrick Williams
Sr. Systems Engineer II
Mechanical Engineering Solutions
Missile Systems
Raytheon Company
+1 520.545.6995 (business)
+1 520.545.6399 (fax)
TU/M12/8
6221 S Palo Verde Rd
Tucson, AZ 85706 USA
www.raytheon.com
This message contains information that may be confidential and privileged.
Unless you are the addressee (or authorized to receive mail for the
addressee), you should not use, copy or disclose to anyone this message or
any information contained in this message. If you have received this
message in error, please so advise the sender by reply e-mail and delete
this message. Thank you for your cooperation.
Jun 18, 2010 2:54 PM UTC
I've used the 64Bit PTK libraries. You just have to have them installed to link against. Easiest way is to setup a 64 bit machine, install 64 bit Pro/E, then link against those libraries. Also you could copy the PTK libraries to your dev system and setup a new makefile etc to compile and link to them.
Patrick Johnson
[cid:image001.jpg@01CB0ED4.B0A28E50]
Jun 18, 2010 3:36 PM UTC
Patrick,
When I did a Pro/I TK app which was used by a 64 bit Pro/TK app, I created a
32 bit Pro/I TK app as an .exe.
Bob
Bob Monat
Jerand Technical Services, Inc.
bob@jerand.com
www.jerand.com
1-317-875-6087
On Fri, Jun 18, 2010 at 10:34 AM, Patrick S Williams <
-> wrote:
> All,
> compiled a Pro/INTRALINK Toolkit application that is 64 bit? I thought the
> toolkit only shipped with 32 bit libraries to link with but I wanted to know
> *Patrick Williams*
> Missile Systems*
> Raytheon Company*
> +1 520.545.6399 (fax)*
> TU/M12/8
> Tucson, AZ 85706 USA*
> **www.raytheon.com*
