About version compatibility
Please tell me how to publish files created with creo7.0 or later with creo5.0.
GCRI does not work between Creo 7 and above to Creo 6 and below.
because of multibody functionality you can use only ... neutral, step, ...
RPN
18-Opal
Can you shed some light on me, and explain why you need do this. For Windchill you can use in most cases the newest available Creo Version, only the output may depend in some cases on your Creo View Version, but even here you can use always the latest.
