3-Newcomer
Add standard notes list
I want to create a list of standard notes and put it in custom ribbon, once I click on that it should show all the pre prepared notes list from where I can pick the required one. Please help me to do this
Chris3
Utilize the note from file (Annotate -> Note -> Note from file) and record different mapkeys to load in text files with the notes you want. Then add the mapkeys into a group in the ribbon.
3-Newcomer
Hi Chris,
Thanks for the response.
I want to create like single mapkey where I can see all standard notes and I would be able to pick the required one.
Any possibility to do so...
Probably not for a single mapkey as there is no programming logic in the creation of mapkeys.
To do what you want is probably going to require custom programming. Some of the third-party content creators, like Etrage or Fishbowl, may already have a program for standard notes.
