Aug 24, 2017 2:05 PM UTC
Add text file to drawing using jlink
 I am trying to add a text file of notes to a drawing using JLink. I have tried using code shown by PTC Located here: https://support.ptc.com/appserver/cs/view/solution.jsp?n=CS206301&lang=en&source=snippet
 but when I change the string to a line read it fails. Here is the code I am using:
DetailNoteItem note = null;
DetailTextLines allLines = DetailTextLines.create();
int number=0;
while(lineRead!=null) // example shows for 3 lines. However, this could be the actual number of lines present in your input text file on disk
String iLineText = "Test " + number; This works but if I change number to lineRead it fails.
DetailTexts iDetailTexts = DetailTexts.create();
iDetailTexts.insert(0, pfcDetail.DetailText_Create(iLineText));
allLines.insert(number, pfcDetail.DetailTextLine_Create(iDetailTexts));
lineRead = textList.readLine();
number++;
textList.close();
// Allocate a note description, and set its properties
DetailNoteInstructions instrs = pfcDetail.DetailNoteInstructions_Create(allLines);
instrs.SetLeader(allAttachments);
// Create the note
note = (DetailNoteItem) drawing.CreateDetailItem(instrs);
note.Show();
20-Turquoise
Aug 24, 2017 7:06 PM UTC
Where is the code that is opening and reading the text file?
What is lineRead?
What is the error message?
Aug 24, 2017 7:16 PM UTC
String textFile = "C:\\data\\Standards\\std-notes\\test.txt";
BufferedReader textList = new BufferedReader(new FileReader(textFile));
String lineRead = textList.readLine();
No error message.
I would prefer to just add the note from file but I am not sure how to do that and have not found any code to show how to do that either.
20-Turquoise
Aug 24, 2017 7:38 PM UTC
No error message.
Ok then what line of code is it failing at?
