Dec 13, 2019 5:24 AM UTC
Adding two buttons to the same group
Hi ,
I have created a ribbon manually. through my toolkit application i am creating a button using ProCmdActionAdd, ProCmdIconSet and ProCmdDesignate. But Iam not able to use same set of functions to create another button. i don get any error but no buttons are getting created . could any one please guide me on this?
Dec 16, 2019 10:37 AM UTC
You need to add it manualy to your ribbon and then export your ribbon definition to your application text directory.
Br,
Eike
Sekar11-VisitorAuthor
Dec 16, 2019 1:23 PM UTC
thank you so much.
I have couple of other queries:
1. Is it possible to add a ribbon or a group through code ?
2. If not, then the only way to add ribbon or group is by manual procedure ie, file ->customize ->Ribbon.
Dec 16, 2019 1:30 PM UTC
1. AFAIK it's not possible to do it only by code.
2. The way described by PTC is to build a "toolkitribbonui.rbn" file inside the text directory of your toolkit application.
-> Customize your ribbons manually
-> Save it from the Creo Parametric Options Editor
    --> Customize --> Ribbon --> Export --> Save the Auxiliary Application User Interface.
Br,
Eike
