Apr 16, 2021 7:38 AM UTC
Amount of edges
hi all,
having simple code such:
public void listEdges() {
try {
Solid mySolid = (Solid) currentSession.GetCurrentModel();
int edgesQTY = mySolid.ListItems(ModelItemType.ITEM_EDGE).getarraysize();
currentSession.UIShowMessageDialog("EdgesQTY: ," +edgesQTY, null);
} catch (jxthrowable e) {
// TODO Auto-generated catch block
e.printStackTrace();
I receive different results. when I have a simple solid part with one extrude feature (10x20x1) as e result I get :12 edges, but when this same is launched in sheetmetal part jlink shows 20 egdes.
Any idea??
Apr 16, 2021 7:51 AM UTC
The sheetmetal part will have green and white surfaces that's why you will get 20 edges. You can ignore the white surface edges. Refer toolkit API "ProSmtSurfaceTypeGet"
  •  PRO_SMT_SURF_FACE—The surface is the face (green) surface created by a sheet metal feature.
  •  PRO_SMT_SURF_OFFSET—The surface is the offset (white) surface created by a sheet metal feature.
Gucio16-PearlAuthor
Apr 16, 2021 8:09 AM UTC
I supposed that topic is connected to green/white surfaces.
Will I be able to check/get only eg. green surfaces in jlink (free license) ??
Apr 16, 2021 8:36 AM UTC
As per my knowledge, it's not possible in jlink (free license). Maybe try to find some workaround by comparing edge and surface, associated with the edge.
Apr 16, 2021 7:16 PM UTC
Without seeing any graphics, I am thinking that the sheet metal model includes the bend tangencies as edges.
