11-Garnet
May 4, 2026 11:07 AM UTC
API for "copy geometry" command and "intersect" command in toolkit.
Hi everyone,
I am looking for an API for "copy geometry" command and "intersect" command in toolkit.
If its there can you help me with that.
remyAnswer
May 5, 2026 11:05 AM UTC
Hi when you search the knowledge base you will find this article :
https://www.ptc.com/en/support/article/CS251415 that suggests to rely on the Element Tree methodology. Consequently there is no direct function per say.
It gives away to look into the shipped example from the header file ProDataShareFeat.h.
Also a code sample has been dropped in this article https://www.ptc.com/en/support/article/CS362850 called
How to create a local reference type copy geometry feature in Creo Parametric through Toolkit
remy21-Topaz IAnswer
11-Garnet
May 5, 2026 11:19 AM UTC
Hi thanks for the reply I will go though the links
