2-Explorer
Aug 28, 2018 11:21 AM UTC
Asm Comp path to Asm comp | ProToolkit
Hello
I have asmcomppath of component in assembly. What I need to do is to allow user to redefine it's constraint. For that, We are going to use API ProAsmcompConstrRedefUI(), which ask for asmcomp.
Query is that how can we fond out ProAsmcomp if we are having proasmcomppath.
Feel free to ask for any query.
Note : we have used ProIdTable to get asmcomppath. ProIdTable (id for components) detail was dumped into model parameter.
Thanks and Regards
Ketan
Aug 30, 2018 2:52 PM UTC
From example TestAsm.c
status = ProSelectionAsmcomppathGet(p_sel[0], &asmcomppath);
p_asmcomp->owner = asmcomppath.owner;
p_asmcomp->id =  asmcomppath.comp_id_table[0];
p_asmcomp->type = PRO_FEATURE;
But I think that for p_asmcomp->id need to use last ID in comp_id_table
Aug 28, 2018 11:53 AM UTC
What about API "ProAsmcomppathMdlGet()" ?
2-Explorer
Aug 29, 2018 1:24 PM UTC
I tried this earlier but it doesn't work as api results MDL handle and for api , we need asmcomp.. As asmcomp has modelitem structure, I checked with mdltomodelitem also, but no success..
Aug 28, 2018 5:11 PM UTC
ProMdl Model;
ProAsmcomppath CompPath;
// Got Asmcomppath
Model = CompPath.owner;
I hope, this is your requirement.
2-Explorer
Aug 29, 2018 1:28 PM UTC
I am ooto and could not check this out today, but I think it may not work... We need asmcomp (similar to modelitem structure), not promdl...
Again another point is that owner of asmcomppath might be top assembly rather than considered item...
I am still not sure and would share results once I will test it tomorrow.. till then if any other method is most welcome..
Thanks and Regards
Ketan
2-Explorer
Aug 30, 2018 6:48 AM UTC
Checked now and it failed... Any other option would be of great help.
