Sep 10, 2020 10:01 AM UTC
Assembly Cut using OTK or ProToolkit
Hello Experts,
I want to cut one part by another in assembly. Manually this can be done using Component Operations->Boolean Operation->Cut.
How can we do it using OTK or Protoolkit.
remyAnswer
Sep 10, 2020 12:27 PM UTC
If you search the knowledge base that you can access with your customer account and search the keywords Boolean Operation assembly cut Toolkit, you will find this article called Example code to create an assembly Merge / Cut Out operation through Creo Parametric Toolkit that deals with the issue: https://www.ptc.com/en/support/article/CS204382
The main takeways:
  1. opt for the Element Tree strategy
  2. an example can be downloaded from the page
remy21-Topaz IAnswer
The main takeways:
