2-Explorer
Jun 18, 2018 4:54 AM UTC
asynchronous toolkit application
Hello I have created dll and exe (synchronous mode ONLY )of toolkit application. Can anyone let me know in which case one should go with asynchronous mode application. I am aware that asynchronous application allow toolkit and Creo (end user operations) execution simultaneously. Is this understanding correct? Additionally, real time example of need to develop asynchronous application would be of great help. Thanks in advance! Regards Ketan
Jun 18, 2018 12:23 PM UTC
Hi Chetan,
congrats on your start with toolkit.
if you look in the documentation you'll learn that (put it simply):
- exe is for asynchronous app: an application drives Creo
- dll is for synchronous app: the app is started within Creo (similarly as a plugin)
if you look in the Creo install you'll also find examples: <common files>\protoolkit\protk_appls\pt_examples
2-Explorer
Jun 19, 2018 5:43 AM UTC
Could not find any example in folder fir asynchronous. Can you tell me name of file to be looked into? I am using Creo 3.0 M120
Jun 19, 2018 6:54 AM UTC
Hi ketan,
You may look into the folder <common files>\protoolkit\protk_appls\pt_async
you'll find c code there.
