Oct 19, 2012 1:13 PM UTC
asyncoremt.dll file is missing
I have the all programms of creo 2.0 student edition installed on my pc. There wasn´t any problem at all.
After I had done this, I tried du run Creo Parametric, but it didn´t work.
I systemfail appeard:
"The programm can not be started. The asyncoremt.dll file is missing on the computer.
Install the programm new, to solve the problem.p"
I copied the licencse in the source @ setup, by moving it with my mouse.
I hope you can help me, thank you
mfg
Jan 31, 2013 10:43 PM UTC
Did you ever find a resolution to this? I had never seen this before today either but one of our users bumped into it.
The file should be located in similar place to D:\ptc\Creo2Parametric_M010\Creo 2.0\Common Files\M010\x86e_win64\lib
If you found out what root cause was i'd be interested to hear, for us the problem no longer repeats and the file was there.
Feb 1, 2013 12:28 AM UTC
One of two things can cause this kind of problem... not having ownership of the Creo install folder and not having the location in your path statement. It is a similar problem as making Purge work. Take ownership of your Creo install folder. If that doesn't solve it, add the ...lib folder to the path statement.
Mar 16, 2014 1:53 AM UTC
Hi All
I have also come across this issue (asyncoremt.dll missing). In fact its quite common in my environment where i would say 75% of the machines ive installed in on give this error. (I install it on a range of school computers)
Most times I am able to change permissions and remove the Read Only access on the PTC folder. This seems to fix it however I have come across one that I cannot get to work.
No matter what I do it still continues to tell me that asyncoremt.dll is missing at start up. (A quick search of the directory shows me that the file is not missing.
The computer has windows 7 home edition and no matter what changes I make to folders permissions, they have reset themselves back to what they were originally as soon as I click on folder properties again.
I have uninstalled and reinstall half a dozen times still with not luck.
Even worse, now when I install it, and I double click to run Creo Parametric, Layout, Thermal, Direct or Structure. Nothing at all happens.
Any help or ideas would be extremely appreciated.
Thanks in advanced.
