Automation of geometry editing process in creo
I want to automate geometry editing process in creo.
The steps are as follows:
1. Importing geometry in creo (e.g. step format) from a directory in desktop.
2 Perform geometry edit feature in creo & save in step format in the same folder. (Trail file regarding this operation is ready and working successfully.)
3. Same process should be repeated for 'n' no. of geometries saved in same folder.
Requesting for your help.
maybe https://community.ptc.com/t5/System-Administration/PTC-Creo-Distributed-Batch/m-p/624616#M25131 discussion will help you to solve your request. Download gentrail_2019-08-30.zip and investigate its contents.
Ok. Thanks..
