Sep 18, 2019 9:00 AM UTC
Automation of PDF Generation process in Creo
Need suggestion on automating PDF generation process in PDM (Creo tool).
Normally PDF file will be generated once CAD file check-in with required modifications. Idea here is to automate PDF generation process once part is check-in. so that one more manual step for generating PDF can be avoided in Creo.
Kindly suggest on
Sep 18, 2019 10:35 AM UTC
I think it is possible to achieve on Windchill side using Creo View Adapters
Sep 18, 2019 11:39 AM UTC
Yes, Windchill can generate pdf while generating the representation after checkin automatically.
Sep 18, 2019 12:59 PM UTC
You need to have CreoView publishing enabled and set up so Windchill can automatically publish your files upon check-in. We also republish them when submitted as part of a promotion request.
