Feb 20, 2026 12:14 PM UTC
Automatization of hyperlinks
I work in Creo Parametric 12.4.1
I want to make my .drw more helpfull, need to automaticaly create Hyperlinks to drawing no from the table of content. I have an assembly with 100 component, in Table>Repeat Region, first cell i have parameter
&asm.mbr.ptc_common_name
This parameter fill for all the position the drawing number.
It is posible to create links to the server of all this files (they are in PDF format) and keep the drw no in the cells?
I found this topic, but didn't find any solution to do it in Creo.
https://community.ptc.com/t5/Creo-Parametric-Ideas/Dynamic-Hyperlinks-in-drawing-and-as-result-updated/idi-p/456420
Community Moderator
Mar 10, 2026 11:42 PM UTC
Hi @GP_12053978,
Thank you for your question.
Anurag
