9-Granite
Oct 16, 2025 5:48 AM UTC
Batch drawing changes using map key and dbatch
I have 100 part numbers , in which the drawing has to be opened from windchill into creo session and it should run a particular already recorded map key then it should save back into the workspace or windchill check in , When i tried running the dbatch program in native creo, it says license error.
My company has customized tools inside creo and its based on floating license i guess. So is there any ways i can link that creo to the dbatch script or i should go with toolkit api commands or trail_file based scripting ?
Does these methods other than dbatch have option to run in background or while the system is ideal (after working hours or scheduled time).
remyAnswer
Oct 22, 2025 11:38 AM UTC
Hi
the most comprehensive article about dbatch is this one : https://www.ptc.com/en/support/article/CS139340
pay specific attention to the known limitations section.
Recently the memory management for large model is also a limitation that has been hit.
All in all i recommend that you follow the recommendation to explore and consider the creation of a custom script-based tooling alternative.
If your company can deliver, invest in Creo Toolkit and create your own batch tool else you can ask a partner.
Oct 17, 2025 12:12 PM UTC
If you are familiar with trail files then you can generate and play trail file instead of running dbatch.
RPN
18-Opal
Oct 17, 2025 10:34 PM UTC
If you open a piping assembly without having the license, no worry as long you don’t try to modify. I have no clue what your mapkey is doing, but I would invest time to configure the right psf file for the right license. A mapkey or trail file will execute like a recorder. This is not the same like open and print!
remy21-Topaz IAnswer
Hi
