Nov 16, 2023 11:47 AM UTC
Button doesn't appear in menu
Hello no matter what I'm doing button doesn't appear in menu. What am I doing wrong?
Whole Code
Imports System
Imports System.Net.Mime.MediaTypeNames
Imports pfcls
Module emptyButton
 Public Sub Main()
 Try
 addTerminationListener()
 AddMenuAndButton()
 'System.Threading.Thread.Sleep(50000)
 Catch ex As Exception
 Console.Write(ex)
 Finally
 End Try
 End Sub
 Private Sub addTerminationListener()
 Dim terminationListener As New ProEExitListener()
 Dim asynconn As New CCpfcAsyncConnection
 Dim session As pfcls.IpfcSession
 Try
 session = asynconn.Connect(Nothing, Nothing, Nothing, 1).Session
 session.asyncConnection.AddActionListener(terminationListener)
 End Try
 End Sub
 Private Class ProEExitListener
 Implements IpfcAsyncActionListener
 Implements ICIPClientObject
 Implements IpfcActionListener
 Public Function GetClientInterfaceName() As String Implements pfcls.ICIPClientObject.GetClientInterfaceName
 GetClientInterfaceName = "IpfcAsyncActionListener"
 End Function
 Public Sub OnTerminate(ByVal _Status As Integer) Implements pfcls.IpfcAsyncActionListener.OnTerminate
 Dim aC As pfcls.IpfcAsyncConnection
 aC = (New CCpfcAsyncConnection).GetActiveConnection
 aC.InterruptEventProcessing()
 End Sub
 End Class
 Private Sub AddMenuAndButton()
 Dim inputCommand As IpfcUICommand
 Dim buttonListener2 As IpfcUICommandActionListener
 Try
 buttonListener2 = New ButtonListener()
 inputCommand = session.UICreateCommand("INPUT", buttonListener2)
 session.UIAddMenu("VB-Async", 'menu name
 Nothing, 'NeighbourItem
 "pfcAsynchronousModeExamples.txt", 'msgFile
 Nothing 'parent
 session.UIAddButton(inputCommand, 'command
 Nothing, 'neighborButton
 "USER Async App", 'ButtonName
 "USER Async Help", 'Message
 "pfcAsynchronousModeExamples.txt" 'msgFile
 Console.Write(ex)
 End Try
 End Sub
 Private Class ButtonListener
 Implements pfcls.IpfcUICommandActionListener
 Public Function GetClientInterfaceName() As String _
 Implements ICIPClientObject.GetClientInterfaceName
 GetClientInterfaceName = "IpfcUICommandActionListener"
 End Function
 Public Sub OnCommand() Implements pfcls.IpfcUICommandActionListener.OnCommand
 Me.UserFunction()
 End Sub
 Public Sub UserFunction()
 Console.Write("hello i'm doing something")
 End Sub
 End Class
End Module
MSG file
#VB-Async
VB-Async
VB-Async
#USER Async App
USER Async App
USER Async App
#USER Async Help
USER Async Help
USER Async Help
#BEDNAR
BEDNAR
BEDNAR
#abc
abc
abc
#bcd
bcd
bcd
#abc Help
abc Help
abc Help
#bcd Help
bcd Help
bcd Help
Nov 17, 2023 7:00 AM UTC
Difficult to say what is wrong.
But menu creation is marked as deprecated in the documentation. This is old style for Proe.
Take a look at the chapter "Workflow to Add Menu Items to the Ribbon User Interface".
First of all try to designate your command "inputCommand" with IpfcUICommand.Designate(). Then check if this command is available in Customize Ribbon
