Apr 6, 2010 8:46 PM UTC
Calculating Thickness for a part using Pro/Toolkit
Hi All,
Is there a way (or methods) in Pro/Toolkit that we can use to calculate the thickness of a part. I know for Sheet Metal parts we should look for thickness parameter but not sure about other types. Any ideas are appreciated.
Thank you,
Krishna.
Apr 6, 2010 9:08 PM UTC
Krishna,
There is not a concept of "thickness" for standard parts. There is a
thickness for a shell feature but not all parts have shell features. I
would look into measuring the distance between two geometry items (top and
bottom surface of a part). Read the API Wizard under User's
Guide->Core:Geometry->Measurement (WF 4.0). Find the
ProGeomitemDistanceEval() function.
Patrick Williams
Sr. Systems Engineer II
Mechanical Engineering Solutions
Missile Systems
Raytheon Company
+1 520.545.6995 (business)
+1 520.545.6399 (fax)
TU/M12/8
6221 S Palo Verde Rd
Tucson, AZ 85706 USA
www.raytheon.com
This message contains information that may be confidential and privileged.
Unless you are the addressee (or authorized to receive mail for the
addressee), you should not use, copy or disclose to anyone this message or
any information contained in this message. If you have received this
message in error, please so advise the sender by reply e-mail and delete
this message. Thank you for your cooperation.
Krishna Konjeti <-> wrote on 04/06/2010 01:46:40
Apr 7, 2010 1:32 AM UTC
Hi Patrick,
Thank you for your quick response.
In one of my application where there is a user interaction (by selecting the top surface)I do use the below mentioned call to calculate the distance till it reaches the end surface. But in the new application I am trying to calculate the thickness for all parts in the model tree and do more calculations with that based on user needs and thats where I get in to trouble. I am thinking of acheiving this by calculating the distance in all three directions and considering the least value as thickness and I am not sure whether it is possible or not but its just an idea right now. Any suggestions is appreciated.
Thank you,
Krishna.
Apr 7, 2010 11:37 AM UTC
Krishna,
You'll want to look at the functions ProSolidOutlineGet() and its cousin ProSolidOutlineComopute() if you need more control over including / excluding non-geometric items such as datums. When you say "thickness" for a model, I assume what you really want is a "bounding box" so you can compare the relative space that each takes in the model tree. These functions will get you want you need.
Good Luck,
Michael Fussy
Apr 7, 2010 2:05 PM UTC
Michael,
Thank you for your reply. I will read the documentation for the methods you mentioned.
Thank you,
Krishna.
