18-Opal
Sep 5, 2019 7:31 AM UTC
Can I adjust the assembly state of the simplified representation?(derived > master)
ProSimprepdataitemsVisit () is for visiting all data items modified by the user. If all component representations are set to the default (derived), no entry is detected.
We informed our customers that in order to use the correct program, they need to modify the derived expression of the simplified item to the master expression.
This is a bit uncomfortable.
Is there a way to use the toolkit to replace all derived states with master representations for some simplified representations?
This part only needs to be applied to the assembly. Even if a component is derived, it does not matter in our case.
If you know any good ideas or APIs, please share them.
FV_01
Oct 14, 2019 10:00 PM UTC
Hello all,
@CHASEONHO you had answered your own question already - if 'no entry is detected' it means all components are members.
ProSolidFeatVisit(...)  to build a ProArray of ProAsmcomppaths, there is an example in protoolkit install directory.
HIH.
FV.
CHASEONHO18-OpalAuthor
18-Opal
Oct 14, 2019 11:48 PM UTC
Your opinion is right.
My idea was short.
Warm Regards,
SeonHo Cha
