Jan 10, 2019 11:59 AM UTC
can I run mapkey in nographics mode using VB API
I have opened Creo in no graphics mode and registered server using VB API
I want to run mapkey using VB API when Creo is opened in no graphics mode
Any help greatly appreciated!!!!
Jan 11, 2019 6:36 AM UTC
Hello!
I'm never try to run mapkey in nongraphic mode, but if you have some problems in this... Try to play trail file instead mapkey
Feb 15, 2019 2:12 AM UTC
IpfcBaseSession.RunMacro();
you can use the class  IpfcBaseSession, it has a method RunMacro, first you need get Session Object, cause Session is the Child of Basesession, so you can use it's methods through Session Module.
