3-Newcomer
Can ModelCheck report an Error if a prt parameter is empty
I am trying to get ModelCheck to check my Part Parameters for any empty parameters.
I would like it to report an error and make the user fill in the parameters that are empty (this cannot be a list, it just needs something/anything in it)
I want the engineers to fill out the Material, condition ect parameters.
Can Modelcheck check these are not empty?
Using Creo 7.0.8.0
dnordinAnswer
Yes.
In the start checks (.mcs files), use the check PRT_PARAMETER DRAWN_BY STR NEQ NULL
The part parameter "drawn_by" must be of type string and not be null (empty).
In the checks (.mch files), specify STARTCHECK is set to error.
Dan N.
dnordin16-PearlAnswer
Yes.
Dan N.
3-Newcomer
thanks that worked
