Mar 26, 2025 1:26 AM UTC
Can not change Note font in VB API
Hi, I encountered an issue when I tried to insert a note to our drawing.  When we are using the same drawing for different project, I like to create a "stamp" like note on the drawing to indicate which project this drawing is used for.
With the following code, I can set font height but cannot change the font. Although notestyle.getfont confirmed the font was applied, but when it showed, it reverted back to default font "Arial".
Did I miss anything?
 note = drawing.CreateDetailItem(noteInstructions)
 noteStyle = (New CCpfcAnnotationTextStyle).Create()
 noteStyle.SetHeight(FontHeight)
 noteStyle.SetFont("ARIALN.TTF")
 note.SetNoteTextStyle(noteStyle)
 Console.WriteLine(noteStyle.GetFont)
 note.Show()
Emeritus
Apr 2, 2025 7:29 AM UTC
Hi @SC_TK,
Thank you for your question.
Best Regards,
Vivek N
Community Moderation Team
