Aug 5, 2013 9:14 PM UTC
Can't Run APIWizard for Toolkit Docs (NullPointerException)
Hi Everyone -
I am unable to run the APIWizard applet for toolkit docs. On Firefox,
the applet (left column) frame shows a tiny red string that reads
"Error: Click for details". When I click that link, I see an
Application Error dialog box showing "NullPointerException" in bold
text. That dialog has a button to show details, which brings up
Firefox's Java Console. The console shows a series of errors, but
doesn't mention NullPointerException.
These results are more helpful than Internet Explorer 8, which hangs
up on the IETestPlugin.html page.
I am running Firefox v22 with the Java Platform SE7 U25 plugin on
Windows 7 64-bit. This error happens on both the Wildfire 5 and
Creo 2 releases of the Pro/Toolkit documentation.
Has anyone dealt with this issue already?
|+| M a r k |+|
Mark Stallard
Rapid Response Development
Business Application Services
Enterprise Services Information Technology
Global Business Services
Raytheon Company
(business)
339-645-6423
(cell)
617-331-5443
235 Presidential Way
Woburn, MA 01801-1060
www.raytheon.com
This message contains information that may be confidential and privileged.
Unless you are the addressee (or authorized to receive mail for the
addressee), you should not use, copy or disclose to anyone this message or
any information contained in this message. If you have received this message
in error, please so advise the sender by reply e-mail and delete this
message. Thank you for your cooperation.
Aug 6, 2013 1:32 AM UTC
Yep, I think we all have dealt with this issue...including PTC!
Aug 9, 2013 1:39 PM UTC
I'm dealing with this issue right now in CREO2 as well.  In IE, I get a message that JavaScript is not enabled.  I go to a testing website and test, I get a message that JavaScript is enabled (?!?)
Trying to test / evaluate / learn JLink is very frustrating.
Christopher F. Gosnell
FPD Company
124 Hidden Valley Road
McMurray, PA 15317
PH:724.941-5540
FX:724.941.8322
www.fpdcompany.com
Jun 23, 2014 1:30 PM UTC
You will need to configure JAVA securities to solve this issue. I have put together a guide which can be found in my blog articlehttp://portal.ptcuser.org/p/bl/ar/blogaid=54
