Jul 9, 2013 3:58 PM UTC
Can't see documentation since Java update
Hello all!
I used to see the doc from here C:/Program Files (x86)/proeWildfire 5.0/protoolkit/protkdoc/NSCPSwing.html but since the last java update the 3rd of July I can't see it anymore cause I get an error :
Plug-in Java 10.25.2.17
Utilisation de la version JRE 1.7.0_25-b17 Java HotSpot(TM) Client VM
Répertoire d'origine de l'utilisateur = C:\Users\Brisseau Emilie
c: effacer la fenêtre de la console
f: finaliser les objets de la file d'attente de finalisation
g: nettoyer la mémoire
h: afficher ce message d'aide
l: vider la liste des chargeurs de classes
m: imprimer le relevé d'utilisation de la mémoire
o: déclencher la journalisation
q: masquer la console
r: recharger la configuration des règles
s: vider les propriétés système et de déploiement
t: vider la liste des threads
v: vider la pile des threads
x: effacer le cache de chargeurs de classes
0-5: fixer le niveau de trace à <n>
Reseting Vectors
Error in URL in ReadFile.java
Error in reading Configuration File
Error in Reading Message File
Errorjava.net.MalformedURLException: no protocol: nullapi.IDX
at java.net.URL.<init>(Unknown Source)
at API_DataManager.init_readAPITreeFile(API_DataManager.java:298)
at API_DataManager.<init>(API_DataManager.java:249)
at apiwizard.init(apiwizard.java:67)
at com.sun.deploy.uitoolkit.impl.awt.AWTAppletAdapter.init(Unknown Source)
at sun.plugin2.applet.Plugin2Manager$AppletExecutionRunnable.run(Unknown Source)
at java.lang.Thread.run(Unknown Source)
Foreground = sun.swing.PrintColorUIResource[r=51,g=51,b=51]
Error in API_JTreeRenderer: Image not found
Max: w = 0, h = 0
Don't you have it?
What can I do?
Thanks!!
Nov 14, 2013 10:57 AM UTC
Hi Emilie,
read this
https://www.ptc.com/appserver/cs/view/case_solution.jsp?n=CS133402&lang=en
I have installed a portable XAMPP, start the tomcat-server and copied the vbapidoc-folder to the tomcat-folder.
Nico
