Oct 27, 2015 8:09 PM UTC
cant install creo other than system drive
Hello everyone,
I am really confused here, when I install creo 3.0 parametric, it automatically goes to my c drive which
is the system drive, even after I set the preferrence installation directory to my d drive, it still installs
to C drive.
I also went in to regedit to change all the default installation directory to D, it works for other software
like java, but for creo, it goes to c again.
My win7 system was reinstalled since i switched from hdd to ssd. i am only using 120gb for my system drive
so i dont want to install apps in c.
Based on my situation, can anybody help resolve my problem? thanks in advanced !
Oct 27, 2015 9:03 PM UTC
After entering 😧 for your install drive, press the enter key.
Just entering a different location does not change it. You need the ENTER to get the install program to 'accept' the change.
xzhang-41-VisitorAuthor
Nov 30, 2015 8:17 PM UTC
Thank you so much
Oct 27, 2015 9:14 PM UTC
So this is not directly related to your question (I think Ben has the correct answer for that.) However, I would recommend keeping Creo and if you use Windchill the workspace cache on your new SSD drive performance will be much faster. I know it takes up a lot of space but, you can always use the spare drive for less demanding applications/files.
