Change Component to User Defined Rep
Can you suggest api to change component in assembly to user defined representation.
Thanks in advance.
FV_01
FV_01Answer
Having ProAsmcomppath for a component and ProSimprep for a user defined representation.
  • get ProSimrepdata with ProSimprepDataGet()
  • get ProSimprepActionType type with ProSimprepdataDfltGet()
  • create a ProSimprepAction with the acquired type
  • create ProSimprepdataitem with  ProSimprepdataitemInit(), use component's ProAsmcomppath  values to fill function arguments
  • add item to a data structure with ProSimprepdataitemAdd()
  • set data with ProSImprepdataSet()
  • free data with ProSimprepdataFree()
FV_01
FV_0117-PeridotAnswer
Navku14-AlexandriteAuthor
Thanks for the reply.
The one I missed was ProSubstitutionInit to change user defined rep.
