Jun 7, 2019 8:35 AM UTC
Change Windows file association for Creo files
Hello guys,
In our company we work with a startup batch script that sets variables and config settings.
If I double click on a Creo file, or open it from our ERP system, Windows has this file (*.prt.1, *.drw.2, *.asm.3 …) associated with Parametric.exe and not our batch script?
If this was for 1 file it is not a problem but it’s for *.1, *.2, *.3, - *.250 and on 10 systems
So, I am looking for an automated way to change file associations.
I tried the following already with no success:
  • I found some files in the Creo installation that we tried to change:
    • C:\PTC\Creo 5.0.4.0\InstallManager\CommonCreated.reg
    • C:\PTC\Creo 5.0.4.0\Parametric\bin\pim\xml\created.reg
      • [HKEY_CLASSES_ROOT\.1]
      • @="C:\\PTC\\CadCorner_Config_Creo5.00\\0_Bin\\Start_Creo5.bat"
      • HKEY_LOCAL_MACHINE\SOFTWARE\Classes\.1
  • Tried with the DOS commands Ftype, and Assoc with no good result.
    • assoc .1=CreoParametric
    • assoc .2=CreoParametric
    • assoc .3=CreoParametric
    • assoc .4=CreoParametric
    • ftype CreoParametric=C:\PTC\CadCorner_Config_Creo5.00\0_Bin\Start_Creo5.bat
Could somebody help us with a solution?
Stefaan
svlaminckAnswer
Jun 21, 2019 8:34 AM UTC
I want to present the solution provided by Daniel Nordin, that was the solution!
See attached file because the forum does not allow the syntax.
Jun 10, 2019 12:17 PM UTC
I opened Command prompt as Administrator and used information from https://stackoverflow.com/questions/28189137/windows-establish-file-association-to-batch-file page.
ASSOC .250=MY.FILETYPE
FTYPE MY.FILETYPE=cmd /c call "D:\users\mh\creo5_parametric\zzz.bat" "%1" %*
svlaminck10-MarbleAuthorAnswer
