Feb 10, 2014 10:46 AM UTC
Changing default settings
I'm working with Direct Modeling 64bit 18.1 (M020) and experiencing a frustrating problem.
I need to change Annotation default settings (viewport color, text, dimensions and so on) and am sure that this operation was already made in the past, since a customized set (created with version 17, with only viewport color changed) is present.
Well, something seems wrong, since no change gets saved; nor creating a new style works. I close, start and no change is kept, the new style is not available.
I see that a new lsp style file may be created manually copying an existing one in C:\PTC\Creo Elements\pM318\Setup\SD_GoldTop_pc\annot\2D_Interface\ConfigStyle\ANNOTATION\Default_Settings, anyway no further change will be saved in it. I guess some variable must refer to the wrong path.
Does anybody know this problem and can help me to solve it?
Thank you everybody.
Marco
mcielokAnswer
Feb 12, 2014 10:21 AM UTC
I answered myself: the trouble is due to a seller's customization, which requires to press a dedicated button before exiting the session. It would have been useful if they told me about this new feature at installation time instead of charging my firm for assistance!
Thanks to those that gave a glance to this issue.
Marco
mcielok14-AlexandriteAuthorAnswer
Marco
