check if Family table exist
Hey
I have a code to check if there is a family table in the part.
This will in Creo 5 return the name of the instance if it ends with "flat" or "flat1"
But in Creo 11 I get a fatal error.
I thing it is because I don't have a Family table in the part.
How can I check of the part have a Family table?
FamilyMember familyMember = (Solid) model;
FamilyTableRows familyTableRows = familyMember.ListRows();
// Find if a flat version existtube
for (int i = 0; i < familyTableRows.getarraysize(); i++) {
FamilyTableRow familyTableRow = familyTableRows.get(i);
if (familyTableRow.GetInstanceName().contains("FLAT1")) flat_name = familyTableRow.GetInstanceName();
else if (familyTableRow.GetInstanceName().contains("FLAT")) flat_name = familyTableRow.GetInstanceName();
if (!"".equals(flat_name)) break;
20-Turquoise
If you are running Creo Parametric 11.0.3.0 or earlier you probably are having this issue:
https://www.ptc.com/en/support/article/CS430963
"Creo Parametric exits when attempting to use Jlink method FamilyTableMember.ListColumns()"
Fixed in Creo Parametric 11.0.4.0
20-Turquoise
akok12-AmethystAuthor
It seems to work
Thank you.
