2-Explorer
Oct 28, 2017 9:30 AM UTC
Coincident constraint in assembly by toolkit
Hello
I would like to set coincident constraint. I am using API ProAsmcompconstraintTypeSet().
I am not able to get what should be set for argument "ProAsmcompConstrType" into API.
Possible values for ProAsmcompConstrType are as below as per user guide:
PRO_ASM_MATE,
 PRO_ASM_MATE_OFF,
 PRO_ASM_ALIGN,
 PRO_ASM_ALIGN_OFF,
 PRO_ASM_INSERT,
 PRO_ASM_ORIENT,
 PRO_ASM_CSYS,
 PRO_ASM_TANGENT,
 PRO_ASM_PNT_ON_SRF,
 PRO_ASM_EDGE_ON_SRF,
 PRO_ASM_DEF_PLACEMENT,
 PRO_ASM_SUBSTITUTE,
 PRO_ASM_PNT_ON_LINE,
 PRO_ASM_FIX,
 PRO_ASM_AUTO,
 PRO_ASM_ALIGN_ANG_OFF,
 PRO_ASM_MATE_ANG_OFF,
 PRO_ASM_CSYS_PNT,
 PRO_ASM_LINE_NORMAL,
 PRO_ASM_LINE_COPLANAR,
 PRO_ASM_LINE_PARL,
 PRO_ASM_LINE_DIST,
 PRO_ASM_PNT_DIST,
 PRO_ASM_INSERT_NORM,
 PRO_ASM_INSERT_PARL,
 PRO_ASM_PNT_ON_LINE_DIST,
 PRO_ASM_PNT_ON_SRF_DIST,
 PRO_ASM_EDGE_ON_SRF_DIST,
 PRO_ASM_EDGE_ON_SRF_ANG,
 PRO_ASM_EDGE_ON_SRF_NORMAL,
 PRO_ASM_ALIGN_NODEP_ANGLE,
 PRO_ASM_MATE_NODEP_ANGLE,
 PRO_ASM_LINE_ANGLE,
 PRO_ASM_EDGE_ON_SRF_PARL,
 PRO_ASM_SRF_NORMAL
I am having Creo 3.0 M120.
Any thought would be of great help.
THanks and Regards
Ketan
