component Surface
In creo toolkit how to visit each component surface?
RPN
RPNAnswer
18-Opal
extern ProError ProSolidBodySurfaceVisit (ProSolidBody *body,
 ProSurfaceVisitAction visit_action,
 ProAppData app_data);
 Purpose: Visits surface in a body
 Input Arguments:
 body - body
 visit_action - action function
 app_data - application data.
 Output Arguments:
 Return Values:
 PRO_TK_NO_ERROR - Function is successful.
 PRO_TK_E_NOT_FOUND- There are no surfaces in specified body.
RPN
RPN18-OpalAnswer
18-Opal
 Input Arguments:
 body - body
 Output Arguments:
 Return Values:
Aravind9813-AquamarineAuthor
Hi Sir. Thanks for your reply
I'm using Creo 3.0 'ProSolidBodySurface' is not available, so I use 'ProSolidSurfaceVisit' but i don't get any value.
my query is I wanna visit each ASM component then i want to visit each component surface.
for visiting each ASM component i use 'ProSolidDispCompVisit' is this correct or else i need to add any API call?
RPN
18-Opal
At top level the component/feature ID is the path. Next you need to use ProAsmcomppathMdlGet(path in, model out). This model handle can be used to get all surface ids.
# Tcl code
# syncronous mode with an active assembly
foreach FID [ps_visit type COMPONENT] {
  set Model [ps_assy component $FID]
  set SurfIDs [ps_visit surfaces $Model]
# Now SurfIDs will contain a list of all surface IDs in Model
Note: If the component model is an assembly you may call the function recursive, because an assembly may not contain surfaces! And take care about the feature status.
