Dec 4, 2018 11:48 AM UTC
ComponentPath to Root
using JLink I am trying to acces the coordinate system of the root assembly while I am on a sub-level part. I am using the method CreateModelItemSelection (ModelItem SelItem, /*optional*/ ComponentPath Path). I am not sure what to use for ComponentPath since I want to access the root assembly.
Neither of the following three approaches succeeded:
"null":
ComponentPath(rootAsm, null)
-> coordinate system of sub-level part is selected
empty intseq:
ComponentPath(rootAsm, intseq.create());
providing (0) as intseq:
intseq idsroot = intseq.create();
idsroot.insert(0, 0);
ComponentPath(rootAsm, idsroot); -> pfcExceptions$XToolkitGeneralError
I don't know if I am missing something here. I appreciate any help and ideas on how to access the top coordinat system!
Thank you and kind regards
Michael
RPN
18-Opal
Dec 4, 2018 1:48 PM UTC
the CompPath with RootAsm and NULL should be valid, the Modelitem is CSYS is not the Feature ID! It's the geom ID, owner is the RootAsm as well.
Try it the other way round, select and dump the result.
MichelH1-VisitorAuthor
Dec 4, 2018 4:34 PM UTC
Hi RPN,
thank you for your quick reply!
Is ist correct to select the CSYS by using ModelItem?
If I do:
ModelItem rootCsys_geom;
rootCsys_geom = rootAsm.ListItems(ModelItemType.ITEM_COORD_SYS).get(0);
Selection selCsys = pfcSelect.CreateModelItemSelection(rootCsys_geom, null);
igesInstrs.SetReferenceSystem(selCsys);
I still do not get the root CSYS.
Kind regards
Michael
Dec 5, 2018 8:03 AM UTC
I changed the code so that there is a ComponentPath instance but only an empty intseq:
ComponentPath rootpath = pfcAssembly.CreateComponentPath(rootAsm, intseq.create());
ModelItem rootCsys_geom = rootAsm.ListItems(ModelItemType.ITEM_COORD_SYS).get(0);
Selection selCsys = pfcSelect.CreateModelItemSelection(rootCsys_geom, rootpath);
The root CSYS is still not selected. Is there a different way to select the geometry of the CSYS?
Kind regards
Michael
