3-Newcomer
Jun 3, 2026 2:20 PM UTC
Configuration CreoDistributed Batch
I would like to add .ttd configuration files to a network share and add them to the task list in Creo Distributed Batch for the design office users. What variable do I need to add to config.pro to do this?
Mahesh_Sharma
22-Sapphire I
Jun 3, 2026 5:26 PM UTC
Hi ​@Docserta
Currently, there is no configuration available to define a custom location for TTD files. However, you can try placing all the required files in your desired location and remove them from the default location. When executing the task, manually navigate to the custom location and select the required TTD file. I hope this helps.
Thanks.
Mahesh_Sharma
22-Sapphire I
Hi ​@Docserta
Thanks.
Docserta3-NewcomerAuthor
3-Newcomer
Jun 4, 2026 8:56 AM UTC
Thank you for your reply
