11-Garnet
Connection between Pro/Toolkit and Object Toolkit C++
I've created Pro/Toolkit customization and I would like to connect to the Creo Parametric instance that is created in another customization, that based on Object Toolkit C++ .
Is such connection possible between different Toolkits possible(Pro/Toolkit and Object Toolkit C++)?
The following article may be helpful for you - "Difference between Creo Parametric TOOLKIT and Creo Parametric Object TOOLKIT C++": https://www.ptc.com/en/support/article/CS154980
Lukasz111-GarnetAuthor
11-Garnet
The Creo Parametric instance was initiated by  Object Toolkit C++ and I tried to connect to the instance.
1. By using Object Toolkit C++ I am able to connect
    pfcAsyncConnection_ptr conn = pfcAsyncConnection::Connect("", "", "", 5000);
    pfcSession_ptr sess = conn->GetSession();
    xstring cid = sess->GetConnectionId();
2. By using Pro/Toolkit I am unable to connect to the same instance
    ProEngineerConnect("","", "", NULL, PRO_B_TRUE,5000, &choice, &handle);
    ProEngineerConnectIdGet(&connID);
Am I doing something wrong in Pro/Toolkit?
Take a look at the documentation chapter "Task Based Application Libraries".
You can interop between a different aux applications in one session (instance) Creo.
Do you want to "talk" between two separate instances Creo Parametric application?
11-Garnet
Correct, or be able to connect to the Creo instance created by another toolkit.
Currently instance created in Object toolkit C++ is not accessible in Pro/Toolkit.
Try this:
ProEngineerConnect(NULL, NULL, NULL, NULL, PRO_B_TRUE,5000, &choice, &handle);
PS: what an error you get from ProEngineerConnect?
