Feb 23, 2015 4:00 PM UTC
Consistent Fatal Error upon Selecting Working Directory in Creo 2 Parametric
So I recently switched to an HP xw660 Workstation at work and have tremendously difficulty selecting working directory and/or opening models in the form of Fatal Errors. It sometimes takes me 30 minutes of tries before I finally am able to select working directory. Sometimes it has another Fatal Error when I try to open a model/assembly. Allowing the model to show up in the preview window sometimes allows me to proceed. (I have the traceback log)
Does anyone have any suggestions? It is getting ridiculously annoying.
I have a 'performance mode' config that works fine. I just need the high quality config to run properly so I can render.
Thanks!
DxDiag stuff:
System Information
Time of this report: 2/23/2015, 10:51:08
Machine name: [name]6600
Operating System: Windows 7 Professional 64-bit (6.1, Build 7601) Service Pack 1 (7601.win7sp1_gdr.150113-1808)
Language: English (Regional Setting: English)
System Manufacturer: Hewlett-Packard
System Model: HP xw6600 Workstation
BIOS: Default System BIOS
Processor: Intel(R) Xeon(R) CPU E5405 @ 2.00GHz (8 CPUs), ~2.0GHz
Memory: 9216MB RAM
Available OS Memory: 9216MB RAM
Page File: 2955MB used, 15472MB available
Windows Dir: C:\Windows
DirectX Version: DirectX 11
DX Setup Parameters: Not found
User DPI Setting: Using System DPI
System DPI Setting: 96 DPI (100 percent)
DWM DPI Scaling: Disabled
DxDiag Version: 6.01.7601.17514 32bit Unicode
Display Devices
Card name: NVIDIA Quadro FX 3500
Manufacturer: NVIDIA
Chip type: Quadro FX 3500
DAC type: Integrated RAMDAC
Device Key: Enum\PCI\VEN_10DE&DEV_029D&SUBSYS_032B10DE&REV_A1
Display Memory: 2270 MB
Dedicated Memory: 238 MB
Shared Memory: 2031 MB
Current Mode: 1680 x 1050 (32 bit) (59Hz)
Monitor Name: HP L2045w Wide LCD Monitor
Monitor Model: HP L2045w
Monitor Id: HWP2695
Native Mode: 1680 x 1050(p) (59.954Hz)
Output Type: DVI
Driver Name: nvd3dumx.dll,nvd3dum
Driver File Version: 9.18.0013.0900 (English)
Driver Version: 9.18.13.900
DDI Version: 9Ex
Driver Model: WDDM 1.0
Driver Attributes: Final Retail
Driver Date/Size: 11/22/2013 20:52:40, 18320400 bytes
WHQL Logo'd: Yes
WHQL Date Stamp:
Device Identifier: {D7B71E3E-41DD-11CF-EA70-26231CC2C435}
Vendor ID: 0x10DE
Device ID: 0x029D
SubSys ID: 0x032B10DE
Revision ID: 0x00A1
Driver Strong Name: oem2.inf:NVIDIA_SetA_Devices.NTamd64.6.1:Section003:9.18.13.900:pci\ven_10de&dev_029d
Rank Of Driver: 00E02001
Video Accel: ModeMPEG2_A ModeMPEG2_C ModeVC1_B ModeWMV9_B ModeVC1_A ModeWMV9_A
