Sep 18, 2019 8:48 PM UTC
Converting a PVZ file to a PNG
How can you convert a PVZ file into a PNG file? Is there an API, or can this be done using something like Publishing Engine which does this as part of the publishing process?
Adam
Sep 19, 2019 10:46 AM UTC
Adam
please provide more details. PVZ is 3D and PNG is bitmap. How do you imagine a conversion?
Sep 19, 2019 12:07 PM UTC
When you publish a dita document to PDF, and other formats, using Arbortext PE, the PVZ files are converted to 2d images, specifically to png. I believe Arbortext PE uses the default view.
Sep 19, 2019 12:15 PM UTC
Hi @AdamElkins ,
I think we cannot say convert , but more how to print a particular view of a pvz to a picture file ( tiff, bmp, jpg .,..ect)
The principle is the same when you do manually
You can open the file in  Creo Parametric or Creo view and you can  make a snapshot of the screen area and save it as picture. In Creo Parametric you can print to tiff or jpg.
If you need to do thin manually you need a tool. So I think a good candidate to implement such tool is Creo Parametric Toolkit but also Creo View toolkit but this requires some programming work.
You need to consider what views / orientation you need to print ... etc
