May 8, 2014 8:44 PM UTC
Converting OTK Objects to Pro/Tk
Hi Everyone -
I've been working with the new Object Toolkit on Creo 2.0 these
past few weeks. Things have been OK so far, but I'm discovering
something that's much harder than it should be: Converting OTK
objects for use in Pro/Toolkit.
So far, the two standout cases are:
- Converting pfcModelItem_ptr to ProModelitem
- Converting pfcModel_ptr to ProMdl
Getting ProModelitem from pfcModelItem_ptr is especially bad
because ProModelitemInit (and its variants) require a ProMdl
argument. I can't find a pfcModelItem_ptr method to get the
parent pfcModel_ptr.
I think I see a path to convert pfcModel_ptr to ProMdl, but
it will probably be more complicated than I like.
Did I miss something in the OTK documentation?
If I can't get a reasonable solution to these problems, then
I'll won't be using Object Toolkit very much this year.
|+| M a r k |+|
Mark Stallard
Business Application Services
Global Business Services Information Technology
Raytheon Company
(business)
339-645-6423
(cell)
617-331-5443
235 Presidential Way
Woburn, MA 01801-1060
www.raytheon.com
This message contains information that may be confidential and privileged.
Unless you are the addressee (or authorized to receive mail for the
addressee), you should not use, copy or disclose to anyone this message or
any information contained in this message. If you have received this message
in error, please so advise the sender by reply e-mail and delete this
message. Thank you for your cooperation.
FV_01
May 9, 2014 1:56 PM UTC
Hi all,
Mark,
I think the trick is to get a converted pointer to ProModelitem.
Try this:
pfcModel_ptr pMdl = Session->GetCurrentModel();
if (pMdl != NULL)
const ProSolid solid = (ProSolid) wfcGetHandleFromObject( pfcObject::cast(pMdl));
pfcModelitem_ptr pMi;
const ProModelitem *p_mi = (ProModelitem*) wfcGetHandleFromObject( pfcObject::cast(pMi) );
Feliks.
In Reply to Mark Stallard:
Hi Everyone -
|+| M a r k |+|
Mark Stallard
Raytheon Company
(business)
339-645-6423
(cell)
617-331-5443
www.raytheon.com
May 9, 2014 2:17 PM UTC
Feliks -
Thank you for your reply to this.
This assumes that the current model will not change after I obtain the
pfcModelitem_ptr. I would prefer to use the pfcModelitem_ptr to obtain
its parent pfcModelitem_ptr. If I can't do that, then I'll have to
carry some additional overhead, such as storing both pfcModel_ptr and
pfcModelitem_ptr, or performing the Pro/Toolkit conversion immediately
whenever I get a pfcModelitem_ptr.
Frankly, the best thing PTC could do here is to provide us with utilities
and/or sample code to perform these conversions. It's unrealistic to
expect OTK to immediately replace Pro/Toolkit - think of how long it
took to replace Pro/Develop.
For now, I'll probably need to write my own conversion utilities.
Thanks again for your reply.
|+| M a r k |+|
Mark Stallard
Raytheon Company
(business)
339-645-6423
(cell)
617-331-5443
www.raytheon.com
May 9, 2014 7:20 PM UTC
I think this is a topic of concern that you should bring up during the face-to-face meetings in June.
Patrick Williams | Engineering Systems | c: 616.947.2110
[cid:image001.jpg@01CF6B9A.43DCC070]
