Jun 8, 2011 9:19 AM UTC
Converting Y B C Coordinate System
I've been given Y,B,C coordinates to draw up various tube models; is there anything within Pro/E or any convertor that can model these tubes?
Normally I model using X, Y, Z cartesian coordinate system which is straight forward.
Any help would be appricated.
Jun 9, 2011 5:35 AM UTC
Hello Andy
Do you can rename your datum coordinate system with ModelCheck.
In the ModelCheck it is possible set configuration options DATUM_RENAME to "y". (If this check is enabled and a specified datum is found in the model, ModelCHECK renames it. Datums to be renamed are specified using the config tags PRT_DATUM_RENAME and ASM_DATUM_RENAME.)
In the start file set:
PRT_DATUM_RENAME YBC XYZ
Note: YBC is old name for coordinate system, XYZ is new name for coordinate system
Vladimir
AndyHills1-VisitorAuthor
Jun 9, 2011 10:16 AM UTC
Hi Vladimir,
Thanks for the information, but I many have lead you up the wrong path!
X, Y, Z are cartesian co-ordinate points
Y, B, C are length between bends, rotation and angle of bends also known as LRA.
It maybe only CNC bending information, I'm not too sure.
Kind regards
Andy
Jun 9, 2011 2:04 PM UTC
Hello Andy
Uppps,I had misunderstood your problem.
With CNC informations I do not have a experience , but at least you know the possibility of renaming of datum features.
Have a nice day.
Vladimir
Jun 9, 2011 8:43 PM UTC
Andy,
If you have the Pro/Piping extension that will give you the reverse capability, that is "YBC" output for NC bending from a completed pipe model; I don't think you can go the other way however. (I may be wrong, not having used Pro/Piping to any great extent.) Have you tried the Pipe feature? (Insert/Advanced/Pipe) This may give you what you need. Otherwise, you should be able to construct what you need using a series of Coordinate Systems and Datum Curves, depending on the complexity of your models. Good luck!
David
Jun 10, 2011 9:38 AM UTC
Vladimir,
Not a problem, thanks for you help.
David,
I've had a quick look at Pro/Pipe and I can't seem to find the Y,B,C input. I think you are right it's only an output and not reversible. The only options with in Pro/Pipe are spherical, cylindrical and Cartesian inputs.
Thanks for you help.
Andy
