Jan 25, 2013 8:46 PM UTC
Copying a non pro/e file
Guru's
In Pro/Toolkit I'm visiting components in assembly, and exporting
drawings as a cgm file to a temporary workorder folder. There are
certain parts that are standard, and I would rather just copy the
existing .cgm from the master cgm folder to my workorder job folder.
How can I copy a file within the program, is there a toolkit function or
any filecopy function? Not looking for exact syntax, just a rough of
what method to use.
Mark Steffke
Engineering System Administrator
The Delfield Company
Manitowoc Foodservice
T 989.775.9215 or 989.773.7981, ext 12484
Integrity, Commitment to Stakeholders, and Passion for Excellence
msteffke15-MoonstoneAuthor
Jan 25, 2013 9:13 PM UTC
Or is there a way to call a dos batch file from within your dll?
Mark Steffke
Jan 25, 2013 9:27 PM UTC
There is a system() function to run any command which is platform
independent.
system() call has a side-effect. On windows it opens a dos window when
executing command (like copying a file) which is annoying for the user.
I would suggest to use CopyFile() function on windows.
Jan 25, 2013 9:48 PM UTC
Thanks, good advice. Will give that a try.
Mark Steffke
Jan 26, 2013 3:19 AM UTC
The system() call will display the command prompt window. Rather, try
CreateProcess().
Alternatively, write your own code to copy the file.
Bob
Bob Monat
Jerand Technical Services, Inc.
bob@jerand.com
www.jerand.com
1-317-875-6087
On Fri, Jan 25, 2013 at 3:48 PM, Steffke, Mark J <mark.steffke@manitowoc.com<br/>> wrote:
> *Mark Steffke*
> *Integrity, Commitment to Stakeholders, and Passion for Excellence*
