2-Explorer
Oct 31, 2013 8:03 PM UTC
Copying and renaming a manufacturing assembly
I have need to copy and rename a manufacturing assembly, with all of it's components, but I am struggling to figure out how to do this while maintaining all of the assembly references. Basically, I am looking for the equivalent ofFile->"Save a Copy". When you save a copy of a manufactuing assembly, pro prompts you to rename the assembly, and then each component.I am working with the VB API in wildfire 4, and I would rather not call a macro or a toolkit dll. Could anyone be of assistance here?
Thanks in advance,
Corey
FV_01
Nov 5, 2013 1:02 AM UTC
Hi all,
Corey,
Copying and renaming manufacturing assembly process is verysimilar to amanual one...
The most simplistic case - no models in session
- create temporary directory
- change working directory to where an assembly tobe processedis located
- set config optionsrelated toretrieval of merged and referenced geometry to retrieve...
- retrieve an assembly in question into session
- change working directory to temporary directory
- backup models to temporary directory
- erase all models from session
- retrieve the assembly from the temporary directory
- rename models in session
- backup to the specified directory
- remove temporary directory.
HIH.
Feliks.
In Reply to Corey Van Sickle:
Thanks in advance,
Corey
2-Explorer
Nov 5, 2013 2:14 PM UTC
Thanks for the reply.
I also got the following to work:
- Use VB to copy all the files in a manufacturing assembly to the directory of choice (the working directory in this situation)
- Using the API to rename and save each file after retrieving it into memory, ending with the .asm (IpfcAssembly) and finally the .mfg (IpfcMFG).
- Use VB to delete the copies that still retain the old name, as the rename method simply made a copy with a new name.
- Run the purge.bat file to remove redundant versions of the files.
- Use VB to change the revision extension for each file to 1
This prevents me from having exceptions for paths to files/directories being too long, without having to temporarily map a network drive or change working directories.
