May 8, 2024 9:00 PM UTC
Create a Simple Draft sketch line
I m struggling to find a way to create a single draft entity line on a drawing sheet.   Looking to create a line at 0,0 and go to 1,0 (x direction) or from 0,0 to 0,1 (y direction).   Can someone point me in the right direction?
RPN
RPNAnswer
18-Opal
May 9, 2024 9:12 PM UTC
Yes, that is wrong, thus will only create temporary lines, or items.
One example as well in UgDtlentityExamples.c
FUNCTION : UsrLineentityCreate()
PURPOSE : Utility to create a line entity between specified points
May 9, 2024 11:16 AM UTC
Sorry, misinterpreted the question. This is about Toolkit.
msteffke15-MoonstoneAuthor
May 9, 2024 12:36 PM UTC
My bad.  Yes I am trying create the line in ProToolkit, with no user input.  Want the line to appear automatically.
RPN
18-Opal
May 9, 2024 5:54 PM UTC
You need the Matrix of ProDrawingBackgroundViewGet()
The window matrix is required as well, because as far I remember x,y,z are screen coordinates.
Multiply the line coords by using the inverse (?) with the Window Matrix, something like this, beside of creating the line.😉
There should be an example in the folder tree.
May 9, 2024 6:31 PM UTC
Thanks 17-peridot,  Is the function to create the line  ProGraphicsLineDraw ?    The line i am creating represents the grain direction on a stainless steel sheetmetal flat.   If I have the line on a special layer it can let our CNC nesting software know the direction of grain constraint.  The line is to be on a drawing with a view of the flat.
/* Transform points by matrix */
 ProUtilPointTrans( trf_matrix, point1, point1 );
 ProUtilPointTrans( trf_matrix, point2, point2 );
 /* Draw the line */
 ProGraphicsPenPosition( point1 );
 TEST_CALL_REPORT( "ProGraphicsPenPosition()", "ProTestGraphicsLineDraw()",
			(ProError)0, 0 );
 ProGraphicsLineDraw( point2 );
 TEST_CALL_REPORT( "ProGraphicsLineDraw()", "ProTestGraphicsLineDraw()",
			(ProError)0, 0 );
FV_01
May 9, 2024 7:13 PM UTC
Mark you are using a wrong API, what you need is ProDtlentityCreate(...). There is  protk example file TestDtlentity.c with working code.
HIH
