8-Gravel
Create combined state with new appearance state via toolkit not possible?
Hello community,
creating a new combined state with a new appearance state is not possible via toolkit?
Is there any workaround out there?
Thanks, Lars
If something not possible create via toolkit, then, sometime, run a mapkey can help. Write manually the mapkey, then play it from your app. Don't know is it possible to achieve what you want using mapkey.
8-Gravel
Hello ysinitsyn!
Thanks for the answer. I know the possibility of ProMacroExecute().
As I know, in synchronous application, the macro is executed at the end?
I have not tried it yet.
I need the macro in between of the function.
You can split your code in two parts.
Register the "button" (command) with contain a second part of the code.
At the end of the first part run a mapkey to create an representation. In the end of the mapkey call the command to execute the second part of the code.
I think, this approach was discussed early at this community.
