Apr 27, 2017 6:48 AM UTC
create popup menu with button clik
can anybody help me how to create popup with button click.The popup must contains label,TextFeild and button.
    Apr 28, 2017 5:38 AM UTC
    Do you mean java (j-link) ?
    May 11, 2017 6:15 PM UTC
    Hi Sangavi,
    A couple of quick questions
    • What version of Creo are you using?
    • What API are you using?
    • By "popup" - do you mean a "PopupMenu" as in what happens when you "right click" somewhere? or do you mean just a "dialog box" with a button?
    If you are looking for an actual "Dialog" box - I would highly recommend using Creo's "UI Editor" to help create your dialog. It is quick and easy to create a dialog with the layout you want, and it will even auto-generate C++ code for you.
    On the other hand... if you are using ProToolkit, and only need a dialog box with some "standard" buttons, then ProUIMessageDialogDisplay should do the trick.
    "Standard buttons" include:
    typedef enum pro_ui_message_button
      PRO_UI_MESSAGE_ABORT = 0, /* Abort from the appln */
      PRO_UI_MESSAGE_RETRY = 1, /* Retry the step */
      PRO_UI_MESSAGE_IGNORE = 2, /* Ignore the event */
      PRO_UI_MESSAGE_CONFIRM = 3, /* Confirm the event */
      PRO_UI_MESSAGE_YES = 4, /* confirm the event */
      PRO_UI_MESSAGE_NO = 5, /* disagree */
      PRO_UI_MESSAGE_OK = 6, /* acknowldge */
      PRO_UI_MESSAGE_CANCEL = 7 /* disacknowledge */
    Some example code (NOTE: I haven't tested this - so hopefully it works haha):
    ProError hello_world {
      ProError err = PRO_TK_NO_ERROR;
      ProUIMessageType message_type = PROUIMESSAGE_INFO;
      ProUIMessageButton *buttons;
      ProUIMessageButton ok_button = PRO_UI_MESSAGE_OK;
      ProUIMessageButton cancel_button = PRO_UI_MESSAGE_CANCEL;
      err = ProArrayAlloc(0, sizeof(ProUIMessageButton), 1, (ProArray*)&buttons);
      err = ProArrayObjectAdd((ProArray*)&buttons, -1, 1, &ok_button);
      err = ProArrayObjectAdd((ProArray*)&buttons, -1, 1, &cancel_button);
      ProUIMessageButton user_picked_this_one = PRO_UI_MESSAGE_CANCEL; // set an initial value just incase
      err = ProUIMessageDialogDisplay(message_type, L"Hello World", L"Hello, World!\nThis is a popup.", buttons, ok_button, &user_picked_this_one);
      if (err == PRO_TK_NO_ERROR && user_picked_this_one == PRO_UI_MESSAGE_OK) {
        return PRO_TK_NO_ERROR; // hooray! ^_^
      return PRO_TK_USER_ABORT;
    "pfcSession::UIShowMessageDialog" is the OTK (C++) equivalent.
    Let me know if this works for you, and feel free to PM me if you have more questions.
    James Sullivan
    CadActive Technologies
