Nov 18, 2019 12:23 PM UTC
Creating a simple 3D model using J-Link
Hello!
I am trying to create a simple model (for example, a cube) only using J-Link.
Started by creating a window:
      Model tryModel = curSession.CreatePart ("Testing1");
      tryModel.Display ();
But it does not appear (I call using the button from Creo).
Does anyone have experience creating models using J-Link?
Help me please.
Regards!
Nov 19, 2019 9:47 AM UTC
Yep, in OTK JAVA is possible.
Take a look at chapter Feature Element Tree in documentation.
For J-Link:
1) Template parts with common geometry. Then you can drive a part by changing dimensions and parameters.
2) Build models using UDFs.
Nov 19, 2019 9:05 AM UTC
Looks not bad.
1) Do you have any exception after Model tryModel = curSession.CreatePart ("Testing1"); ?
2) After call CreatePart ("Testing1"); take a look at the session of Creo. Model is exist but not shown?
3) pfcSession.BaseSession.CreatePart return Part type not Model. Maybe, a trick is there.
ps: But in J-Link you can't create features (sketches, extrude and so on)
VladiSlav17-PeridotAuthor
Nov 19, 2019 9:40 AM UTC
Thanks for the answer!
I managed to create the part using this code.
Now the question is how to extrude there ...
You said that J-Link cannot do this. It seemed to me that way too, while I was dealing with him all this time.
Please tell me can I do this with OBJECT TOOLKIT Java?
Do you know any suitable methods from there?
Best Regards!
For J-Link:
