Creating Zero Dimension
- 2 replies
- 1214 views
- Translate All
Hello All,
PTC SPR # 2158086
Is anyone had a sucess in the past creating Zero Base dimension using Creo toolkit API. The current API seemed to be working for creating normal dimension but when it comes to intersection dimension it does not, it thorwing some unexpected results. Suppling dimsense is the key here.
If would be very helpful, if someone can share their expereince (if any) or know how to get it done by otherway around.
Thanks in advance.
Doss
